Is Your ArmSoM Sige7 Root Filesystem on NVMe, eMMC or microSD? Check Before Reflashing
Seeing an NVMe SSD in Linux means the system detected it. It does not, by itself, mean that the running root filesystem is on that SSD.
Before repeating an installation, inspect the current mounts. The commands below read information; they do not format or flash storage.
1. Identify the filesystem mounted at /
Run on the board:
findmnt --target / -o SOURCE,TARGET,FSTYPE,OPTIONS
The SOURCE column identifies the source of the filesystem containing /. TARGET shows its mount point, and FSTYPE shows the filesystem type. See the findmnt manual.
For a straightforward partition-backed installation, a source such as /dev/nvme0n1p2 indicates that the root filesystem is on that NVMe partition. This is an illustrative path, not an expected result for every image.
If the source is an overlay, device-mapper device or another layered filesystem, report the output rather than inferring the physical disk from its name alone.
2. Compare the storage layout
lsblk -o NAME,SIZE,TYPE,FSTYPE,MOUNTPOINTS
Look for the partition mounted at /. An SSD listed without that mount point may be unused, mounted elsewhere, or used only for data.
MOUNTPOINTS can show several mount locations for a device. If an older lsblk rejects that column, use MOUNTPOINT instead. See the lsblk manual.
Do not assume that mmcblk0 always means eMMC or that mmcblk1 always means microSD. Confirm the actual devices for your board and image before any later write operation.
3. Separate root storage from the boot chain
The root filesystem location does not identify where the early loader, U-Boot or kernel was loaded from. Different boot stages can use different storage devices.
Our existing Sige7 NVMe installation discussion describes a setup involving eMMC and NVMe. Treat its procedure as image-specific, and check compatibility before applying it to a different image.
If the root filesystem is not where you expected, save the two command outputs and a full UART startup log. Include the image filename and which storage devices were attached during power-on.
That evidence gives support a clearer starting point than another blind reflash.
