Moving an Application to ArmSoM AIM7: Audit Software Dependencies Before Porting
Concept illustration—not a photograph of ArmSoM hardware.
Moving an application between ARM devices can look straightforward until it reaches a platform-specific library. The source code may be portable while a camera component, binary package or accelerator dependency is not.
ArmSoM AIM7 is an RK3588-based compute module. When evaluating it for an existing application, treat hardware integration and software portability as separate work items. Similar module interfaces do not establish compatibility with another vendor’s drivers or acceleration stack.
Make a dependency inventory
Before changing code, list the parts the application actually needs:
  • Runtime and language versions.
  • Native libraries and architecture-specific binaries.
  • Camera, display and other device interfaces.
  • GPU or NPU dependencies.
  • System services, permissions and configuration files.
Mark each dependency as portable, requiring replacement, or still unverified. An ARM64 package is only one part of the check; operating-system libraries and device-specific dependencies also matter.
Establish a software-only baseline
Where practical, start with recorded or synthetic input and a portable implementation of the application’s core logic. Preserve representative inputs and expected outputs.
This baseline helps separate application regressions from platform integration problems. If a dependency has no usable implementation on the target, identify that early instead of assuming an image change will solve it.
Treat acceleration as an explicit migration
An application built around CUDA or TensorRT should not be assumed to run unchanged on Rockchip hardware. Identify which operations need a supported replacement and check the relevant toolchain before committing to the port.
Likewise, packaging software in a container does not supply missing host drivers. Verify architecture, host support and the specific device access required; do not grant unrestricted device access merely to make an error disappear.
Keep the migration reviewable
Track each dependency’s status and the test used to validate it. Record the carrier, image, kernel and application revision with every integration result.
Considering AIM7 for an existing ARM application? Share the software stack and its platform-specific dependencies. That is a better starting point than asking whether the entire application is simply “compatible.”
