Planning an ArmSoM Sige7 Home Server: Test Networking, Storage and Applications Separately
A compact home server might hold project files, serve a local dashboard, or host a personal development environment. Before combining those jobs, find out which part of the system each one depends on.
ArmSoM’s product comparison lists Sige7 with the Rockchip RK3588, two 2.5GbE ports, and an M.2 Key M interface for a 2280 NVMe SSD over PCIe 3.0 x4. These are useful building blocks for a home-server evaluation—not a promise of any particular file-transfer speed.
1. Define one useful first service
Start with a single workload, such as sharing a test folder with one computer. Specify the client, file sizes and expected number of simultaneous users. Small source-code files and large video files create different workloads.
Use disposable test data until you have verified permissions, storage behavior and recovery. Do not make an experimental setup the only home for important files.
2. Separate the three performance questions
  • Network: What speed does the complete link negotiate? Check the board, switch, client adapter and cabling. Two Ethernet ports do not automatically double the bandwidth of one transfer.
  • Storage: Can the selected SSD sustain the workload after caches fill and the enclosure warms up? Record the drive model, filesystem and free space.
  • Application: How does the actual file-sharing or server application behave with your settings? Encryption, many small files and concurrent clients can change the result.
Test these separately before treating a slow file copy as a board limitation. When sharing measurements, distinguish network throughput in bits per second from file-transfer rates in bytes per second.
3. Plan for operation, not just the first boot
Provide cooling suited to sustained use and follow the board’s power requirements. Start with local-network access, use appropriate authentication, and avoid exposing administration interfaces directly to the internet.
Finally, maintain a separate backup and test restoring a file. A working server—or redundant storage—is not itself a backup strategy.
Which first service would you put on Sige7? Post your client network speed, storage choice and workload, and use those requirements to shape the build.
