My board keeps booting in a loop, how can I solve this problem?
Please check whether you are connected to a 12v3a power adapter or Type-C fast charge
What I am connecting now is a USB to Type-C cable. Do you mean that Type-C fast charging is needed to start the system?
Yes, armsom-w3 currently supports 12v3a power adapter and Type-C fast charging to boot the system
If you only connect the USB to Type-C cable, the power supply will be insufficient and it will keep restarting.
Thanks for the reminder, now the loop restart problem has been solved
