About the ArmSoM-CM5 category
Discuss ArmSoM-CM5 setup, operating systems, interfaces, troubleshooting and projects.
Getting started
Find the matching product manual in the ArmSoM documentation, and use the community resource guide for downloads, first boot and troubleshooting links.
Posting in this category
Include the exact product and hardware revision, carrier board if used, image filename, kernel version, power supply and connected peripherals. Describe the expected result, actual result and steps to reproduce. Add relevant logs in a code block and explain what you have already tried.
Project writeups are welcome: share your setup, results and lessons learned. English and Chinese are both welcome.
中文提问请提供型号、系统版本、复现步骤与日志;跨产品问题可发布在 General 分类。
