Concept illustration—not a photograph of ArmSoM hardware.
A digital signage player needs to do more than play one demonstration clip. It should start predictably, repeat content reliably and remain usable when the network is unavailable.
ArmSoM Sige1 is based on the Rockchip RK3528. Its official specifications describe multimedia capabilities and HDMI output, making a focused signage prototype a practical use case to evaluate. However, a chip’s decoding capability does not prove that a particular browser or player will use it.
Separate output resolution from decoding
A display reporting a 4K signal does not establish that video is being hardware-decoded. Treat these as separate checks:
- Can the display accept the intended output mode?
- Does the chosen image provide the required multimedia components?
- Can the player decode the actual content format through the intended path?
- Does playback remain smooth over repeated loops?
Keep the exact image and player version with your results. Avoid describing all files with the same extension as equivalent: codec, profile, bit depth and bitrate matter too.
Start with a local content loop
Use a small playlist stored locally before adding streaming, remote updates or a browser dashboard. Include the transitions your final presentation will use, not just its easiest clip.
Record:
Board revision and image:
Player and version:
Display mode:
Clip codec, profile, resolution and frame rate:
Audio output:
Loop duration and observed issues:
Watch for blank frames at transitions, audio drift, stalled playback and resource usage that keeps growing. If problems appear, change one variable at a time.
Design the unattended experience
Test a normal reboot, automatic player startup and recovery after network loss. Decide what the screen should show when new content cannot be downloaded. Keep a known-good local fallback and a way for an operator to recover the device.
What would you display on a Sige1-based signage prototype: a video loop, an information dashboard or a mixed playlist? Share the content format and uptime requirements to make the discussion concrete.
