Building an Edge AI Prototype on ArmSoM Sige5: Validate the Model Before the Full Application
An edge AI prototype becomes useful when it produces the right result, within the required time, on real input—not simply when a demo launches.
ArmSoM Sige5 combines the Rockchip RK3576 with an NPU rated at up to 6 TOPS for INT8 workloads. That makes it a candidate for evaluating local vision and inference projects, but the headline number is not an application frame-rate guarantee. See the Sige5 specifications.
Start with a small acceptance test
Before connecting cameras or building a dashboard, write down:
  • The exact model and input dimensions.
  • A small set of representative test inputs, including difficult cases.
  • The expected output and acceptable accuracy loss.
  • Your latency target and intended continuous operating time.
Use this test set throughout development. Otherwise, changing the model and input data together can hide regressions.
Validate in three stages
1. Establish the reference result. Run the original model in its supported environment and retain its outputs. Record preprocessing details, including resizing, channel order and normalization.
2. Validate the board deployment. Use a deployment toolchain that explicitly supports RK3576 and your model’s operators. Check its requirements against the board image, driver and runtime versions. Compare results on the same inputs before optimizing speed. A successful conversion alone does not establish correctness.
3. Add live input. Connect the acquisition and output stages only after the fixed-input test works. Measure the time from receiving an input to producing the result your application actually uses. Include preprocessing, transfers, inference and postprocessing—not just the accelerator’s execution time.
Make the result reproducible
Run the intended workload long enough to expose thermal or memory problems. Keep the image filename, software versions, cooling arrangement, model version and test settings with your measurements.
Sige5 is a starting point for exploring a local AI workflow; your acceptance test determines whether that workflow fits the application.
What are you building: visual inspection, object detection, or another local inference task? Share the model, input size and latency target so the discussion can focus on a concrete deployment.
The staged validation makes sense, but I’m unsure how much time to spend on the reference result before touching the board. I’m planning a small RK3576 setup for a workshop defect-detection test with a fixed camera and a few hundred labeled images, and my worry is that operator support will force a model swap after I’ve already recorded baselines. Did anyone here lock preprocessing details first and only then pick the deployment toolchain? Also, this revenue item is unrelated, but I saw OpenAI quarterly revenue reportedly tops $10 billion while digging around and it made me wonder how long these prototype cycles really run.
That’s a fair concern—the stages are validation gates, rather than a reason to postpone all board testing.
I’d start with a small, representative subset of your labeled images, including subtle defects and clean examples. Record the candidate model’s reference outputs and preprocessing, then do an early conversion and on-board check before investing in a full baseline.
I wouldn’t lock preprocessing independently of the model and toolchain. Document what the candidate model expects—resize or crop behavior, channel order, normalization—and verify that the deployed pipeline reproduces it. If compatibility forces a model swap, keep the same evaluation images and acceptance criteria, but establish a new model-specific baseline.
For your workshop test, that first pass should answer two questions: does the candidate deploy, and does it preserve useful defect-detection results? Expand the evaluation once both look promising.
Which model are you considering, and what’s the smallest defect you need to detect at your chosen input resolution?
