Evaluating ArmSoM Forge1 for an Industrial Gateway: Start with the Data Path
An industrial gateway project is often defined less by peak CPU performance than by how reliably it collects, buffers and delivers data.
ArmSoM Forge1 uses the Rockchip RK3506J triple-core Cortex-A7 processor. Its official documentation lists 512MB DDR3L memory, two 100Mbps Ethernet interfaces and a Buildroot-based software offering. This makes a focused, resource-conscious gateway or control-interface prototype a useful direction to evaluate.
Describe the complete data path
Write down the field device, physical interface, application protocol, sample rate and destination. For example, a proposed project might collect measurements from a bench device, retain a local queue during a network outage and forward records when connectivity returns.
That is a project concept, not a claim of a preinstalled or validated solution. Verify which interfaces are exposed on your board revision and whether the required transceivers, isolation and drivers are present. Processor peripheral support alone is not enough.
Budget for interruption
Estimate the storage needed during an outage:
record size × records per second × outage duration
Then allow extra space for metadata, logs and the storage format. Define what happens when the queue fills: stop sampling, discard older records, or raise an alert. Make that behavior intentional and visible.
Test recovery on a bench setup
Use a non-production device or simulator to test cable disconnection, destination downtime, application restart and malformed input. Check whether timestamps, record order and duplicate handling meet your application’s needs.
If the design includes control outputs, define a safe state before injecting faults. Do not experiment on live machinery.
Validate the complete assembly
The board’s documented temperature range is not certification of your enclosure, display, power supply or connected equipment. Likewise, real-time behavior must be demonstrated for the actual software and workload rather than inferred from a feature list.
Considering Forge1 for a gateway or HMI? Share your protocols, sampling rate, buffering requirement and display needs. Those details are more useful for an initial architecture discussion than a CPU comparison alone.
One addition on the buffering side: pick a queue format that survives sudden power loss, since field cabinets rarely get a clean shutdown. An append-only log with per-record checksums and batched fsync is usually easier to reason about than an in-place database update, and it also spreads writes across the flash. Also worth sizing against the network: two 100Mbps ports bound aggregate throughput to roughly 12MB/s per port before protocol overhead, so a high sample rate with verbose framing can saturate the link long before the CPU or the queue does.
