Forge1从SD卡启动的问题。
  1. 我使用flash_erase把mtd0清空了。
  2. 我使用SD_Firmware_Tool.exe(瑞芯微创建升级磁盘工具 v1.76),选择“SD启动”,烧写了“armsom_forge1_sd_defconfig_20250929.img”这个image。
  3. 使用SD卡启动以后,报如下错误:
问题:
  1. 该如何正确使用SD卡启动。
  2. 如果我想使用armbian 社区的镜像,该怎样烧录,我用balenaEtcher烧录的SD卡一直报GPT CRC错误,换了一块卡也不行。
万分感谢!
[ 12.443291] platform vdd-arm: deferred probe pending
DDR 0ac6b06a19 typ 24/11/13-17:22:47,fwver: v1.04
tREFI:4x, sr_idle:93, pd_idle:13
PHY drv:clk:40,ca:48,DQ:40,odt:240
vrefinner:50%, vrefout:50%
dram drv:40,odt:120
sr_dq:0, sr_ca:0, sr_clk:0
rg:0x1-0x1-0x2, 0x38-0x0-0x2,status:a007
rdtrn:0x11-0x2e-0x4b(0x3a)
wrtrn:0x0-0x20-0x3f(0x3f)
DDR3, 750MHz
BW=16 Col=10 Bk=8 CS0 Row=15 CS=1 Size=512MB
out
U-Boot SPL board init
U-Boot SPL 2017.09 (May 15 2025 - 11:24:07)
sfc cmd=03H(6BH-x4)
SPI Nand ID ef aa 23
unrecognized JEDEC id bytes: ff, ef, aa
Trying to boot from MTD1
Trying fit image at 0x2000 sector
Not fit magic
Trying fit image at 0x3000 sector
Not fit magic
Trying to boot from MMC1
GUID Partition Table Entry Array CRC is wrong: 0x96bc0ffb != 0x7e31aecc
Repair the backup gpt table OK!
Verified-boot: 0
Checking optee 0x00001000 … sha256(690eb8a14d…) + OK
Trying kernel at 0xbf00 sector from ‘boot’ part
fit_find_config_node: Missing FDT description in DTB
No matching DT out of these options:
U-Boot FIT source file for arm
Invalid dtb
Jumping to Kernel(0x00200000) via OP-TEE(0x00001000)
Total: 383.387/428.688 ms
I/TC:
I/TC: Status: cluster=0xc00, core=0xe100, bootcpu=0
I/TC: Next entry point address: 0x00200000
I/TC: OP-TEE version: 3.13.0-894-g0e7e5b3c7ff #chenjh (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Tue Nov 12 09:21:23 CST 2024 arm, fwver: v1.25
I/TC: OP-TEE memory: TEEOS 0x5e000 TA 0x1000 SHM 0x1000
I/TC: Primary CPU initializing
E/TC:0 0 rk_otp_sbpi_read:353 otp_check_ecc fail! parity=0x20
E/TC:0 0 rk_otp_read:789 —OTP—sbpi read otp failed! addr: 0x1ff
E/TC:0 0 call_initcalls:24 Initcall __text_start + 0x0001a280 failed
I/TC: Primary CPU switching to normal world boot
  1. 我们使用RKDevTool 进入loader模式(插入adb后, RKDevTool 页面上可以切换),清除 EraseAll后
  2. 使用SD_Firmware_Tool.exe(瑞芯微创建升级磁盘工具 v1.78),选择“SD启动”,烧写了“armsom_forge1_sd_defconfig_20250929.img”这个image。
启动成功
  1. 使用armbian 固件 balenaEtcher烧录 的时候需要以管理员的身份打开 balenaEtcher
非常感谢,我试一下。
我点击"upgrade firmware"页面中的switch后,等一分钟左右,进入"Advanced Function"界面,点击"EraseAll", 报了以上错误,请问这是什么引起的?
如果我没有点击"switch",则在"EraseAll"时,报上边的错误。
你需要点switch,切换到loader模式
你好,我使用12V给forge1供电,使用USB A转 type-c线连接到板子的type-c口,RKDevTools 用的v3.30,
  1. 一开始板子上type-c口旁边的绿色led是亮的,RKDevTool的下方显示“发现一个ADB设备”。
  2. 我转到“升级固件”标签页,点击“切换”,显示“切换RockUsb”开始。
  3. 大约等1分钟后,右侧显示“切换RockUsb成功”,但是下方显示“没有发现设备”。
  4. 我切换到“高级功能”标签页,点击"擦除所有",提示“没有发现设备,停止执行!”
请帮我看下,哪里有问题,多谢!
因为新用户不能发出一张以上图片,我在后边补齐。
您试试,把12v dc 供电拔电,用typec供电
然后再进行上面的切换,清除操作。
还是报一样的错误。
  1. 更换一下usb的线
  2. 使用命令,reboot loader 看是否可以进入loader模式
reboot loader 还是工具切换,我这边试了都可以
您好,使用工具切换时,可以看到新的load被载入启动了,但是可能执行中哪里出错了,把log发出来,请看下可能错在哪里。
多谢!
看日志最后已经进入loader模式了,程序和日志都没有问题。
前面问题找到了,因为电脑没有安装Rockchip的驱动。
再次感谢!
请教老师,我forge1刚开始sd卡刷完启动时,主板只有一个蓝灯常亮,我认为没刷成功。后来看上面的帮助贴,重新刷了一下,现在主板有绿灯闪烁了,但我用 Angryip 找forge1的IP地址时,却扫描不到,只能显示扫描到了主机的IP。我刷的镜像是armsom_forge1_sd_defconfig_20250929.img,扫不到IP,与这个镜像有关系吗?
镜像应该没问题,您可以接串口看看,实际网络ip 是多少。
调试串口的连接方式再这篇帖子里面有哈
收到,我试试。感谢!
问题解决!谢谢!
