The model we bought is the EC200A-CN domestic version of Yuanyuan Communication, help to do the kernel configuration
You turn on these macro switches in the kernel
- usb to serial port function
CONFIG_USB_SERIAL
CONFIG_USB_SERIAL_WWAN
CONFIG_USB_SERIAL_OPTION
- usb card driver
CONFIG_USB_USBNET=y
CONFIG_USB_NET_CDCETHER=y
CONFIG_USB_NET_RNDIS_HOST=y
CONFIG_USB_NET_QMI_WWAN
CONFIG_USB_WDM
CONFIG_USB_NET_DRIVERS
CONFIG_USB_USBNET
- Supports the PPP dialing function
CONFIG_PPP
CONFIG_PPP_ASYNC
CONFIG_PPP_SYNC_TTY
CONFIG_PPP_DEFLATE
            The kernel configuration did not add vid and pid. After turning on the above macro switch, the device can be recognized, but the module does not work, the module vid: 2c7c and pid: 6005
diff --git a/kernel/drivers/usb/serial/option.c b/kernel/drivers/usb/serial/option.c
index 5636b8f52..de29ba5fc 100644
--- a/kernel/drivers/usb/serial/option.c
+++ b/kernel/drivers/usb/serial/option.c
@@ -606,6 +580,32 @@ static void option_instat_callback(struct urb *urb);
 static const struct usb_device_id option_ids[] = {
+#if 1 //Added by Quectel
+	{ USB_DEVICE(0x05C6, 0x9090) }, /* Quectel UC15 */
+	{ USB_DEVICE(0x05C6, 0x9003) }, /* Quectel UC20 */
+	{ USB_DEVICE(0x05C6, 0x9215) }, /* Quectel EC20(MDM9215) */
+	{ USB_DEVICE(0x2C7C, 0x6005) }, /* Quectel EC20(MDM9x07)/EC25/EG25 */
+	{ USB_DEVICE(0x2C7C, 0x0121) }, /* Quectel EC21 */
+	{ USB_DEVICE(0x2C7C, 0x0191) }, /* Quectel EG91 */
+	{ USB_DEVICE(0x2C7C, 0x0195) }, /* Quectel EG95 */
+	{ USB_DEVICE(0x2C7C, 0x0306) }, /* Quectel EG06/EP06/EM06 */
+	{ USB_DEVICE(0x2C7C, 0x030B) }, /* Quectel EG065K/EG060K */
+	{ USB_DEVICE(0x2C7C, 0x0514) }, /* Quectel BL EG060K RNDIS Only */
+	{ USB_DEVICE(0x2C7C, 0x0512) }, /* Quectel EG12/EP12/EM12/EG16/EG18 */
+	{ USB_DEVICE(0x2C7C, 0x0296) }, /* Quectel BG96 */
+	{ USB_DEVICE(0x2C7C, 0x0700) }, /* Quectel BG95/BG77/BG600L-M3/BC69 */
+	{ USB_DEVICE(0x2C7C, 0x0435) }, /* Quectel AG35 */
+	{ USB_DEVICE(0x2C7C, 0x0415) }, /* Quectel AG15 */
+	{ USB_DEVICE(0x2C7C, 0x0452) }, /* Quectel AG520 */
+	{ USB_DEVICE(0x2C7C, 0x0455) }, /* Quectel AG550 */
+	{ USB_DEVICE(0x2C7C, 0x0620) }, /* Quectel EG20 */
+	{ USB_DEVICE(0x2C7C, 0x0800) }, /* Quectel RG500/RM500/RG510/RM510 */
+	{ USB_DEVICE(0x2C7C, 0x0801) }, /* Quectel RG520/RM520/SG520 */
+	{ USB_DEVICE(0x2C7C, 0x6026) }, /* Quectel EC200 */
+	{ USB_DEVICE(0x2C7C, 0x6120) }, /* Quectel UC200 */
+	{ USB_DEVICE(0x2C7C, 0x6000) }, /* Quectel EC200/UC200 */
+	{ .match_flags = USB_DEVICE_ID_MATCH_VENDOR, .idVendor = 0x2C7C }, /* Match All Quectel Modules */
+#endif
 	{ USB_DEVICE(OPTION_VENDOR_ID, OPTION_PRODUCT_COLT) },
 	{ USB_DEVICE(OPTION_VENDOR_ID, OPTION_PRODUCT_RICOLA) },
 	{ USB_DEVICE(OPTION_VENDOR_ID, OPTION_PRODUCT_RICOLA_LIGHT) },
@@ -1665,8 +1593,7 @@ static const struct usb_device_id option_ids[] = {
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x1272, 0xff, 0xff, 0xff) },
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x1273, 0xff, 0xff, 0xff) },
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x1274, 0xff, 0xff, 0xff) },
-	{ USB_DEVICE(ZTE_VENDOR_ID, 0x1275),	/* ZTE P685M */
-	  .driver_info = RSVD(3) | RSVD(4) },
+	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x1275, 0xff, 0xff, 0xff) },
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x1276, 0xff, 0xff, 0xff) },
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x1277, 0xff, 0xff, 0xff) },
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x1278, 0xff, 0xff, 0xff) },
@@ -1739,6 +1664,7 @@ static const struct usb_device_id option_ids[] = {
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x0060, 0xff, 0xff, 0xff) },
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x0070, 0xff, 0xff, 0xff) },
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x0073, 0xff, 0xff, 0xff) },
+	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x0094, 0xff, 0xff, 0xff) },
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x0130, 0xff, 0xff, 0xff),
 	  .driver_info = RSVD(1) },
 	{ USB_DEVICE_AND_INTERFACE_INFO(ZTE_VENDOR_ID, 0x0133, 0xff, 0xff, 0xff),
@@ -2202,7 +2097,26 @@ MODULE_DEVICE_TABLE(usb, option_ids);
  * recognizes separately, thus num_port=1.
+static void cfmakeraw(struct ktermios *t)
+	t->c_iflag &= ~(IGNBRK|BRKINT|PARMRK|ISTRIP|INLCR|IGNCR|ICRNL|IXON);
+	t->c_oflag &= ~OPOST;
+	t->c_lflag &= ~(ECHO|ECHONL|ICANON|ISIG|IEXTEN);
+	t->c_cflag &= ~(CSIZE|PARENB);
+	t->c_cflag |= CS8;
+	t->c_cc[VMIN] = 1;
+	t->c_cc[VTIME] = 0;
+static void option_init_termios(struct tty_struct *tty)
+	cfmakeraw(&tty->termios);
+#endif
 static struct usb_serial_driver option_1port_device = {
+	.init_termios  = option_init_termios,
 	.driver = {
 		.owner =	THIS_MODULE,
 		.name =		"option1",
@@ -2229,6 +2143,9 @@ static struct usb_serial_driver option_1port_device = {
 #ifdef CONFIG_PM
 	.suspend           = usb_wwan_suspend,
 	.resume            = usb_wwan_resume,
+	.reset_resume = usb_wwan_resume,
+#endif
 #endif
@@ -2253,6 +2170,35 @@ static int option_probe(struct usb_serial *serial,
 				&serial->interface->cur_altsetting->desc;
 	unsigned long device_flags = id->driver_info;
+	//Quectel UC20's interface 4 can be used as USB Network device
+	if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) && serial->dev->descriptor.idProduct == cpu_to_le16(0x9003)
+		&& serial->interface->cur_altsetting->desc.bInterfaceNumber >= 4)
+		return -ENODEV;
+	//Quectel EC20(MDM9215)'s interface 4 can be used as USB Network device
+	if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) && serial->dev->descriptor.idProduct == cpu_to_le16(0x9215)
+		return -ENODEV;
+	if (serial->dev->descriptor.idVendor == cpu_to_le16(0x2C7C)) {
+		__u16 idProduct = le16_to_cpu(serial->dev->descriptor.idProduct);
+		struct usb_interface_descriptor *intf = &serial->interface->cur_altsetting->desc;
+		if (intf->bInterfaceClass != 0xFF || intf->bInterfaceSubClass == 0x42) {
+			//ECM, RNDIS, NCM, MBIM, ACM, UAC, ADB
+			return -ENODEV;
+		if ((idProduct&0xF000) == 0x0000) {
+			//MDM interface 4 is QMI
+			if (intf->bInterfaceNumber == 4 && intf->bNumEndpoints == 3
+				&& intf->bInterfaceSubClass == 0xFF && intf->bInterfaceProtocol == 0xFF)
+				return -ENODEV;
+#endif
 	/* Never bind to the CD-Rom emulation interface	*/
 	if (iface_desc->bInterfaceClass == USB_CLASS_MASS_STORAGE)
 		return -ENODEV;
@@ -2366,7 +2312,7 @@ static void option_instat_callback(struct urb *urb)
 		dev_dbg(dev, "%s: error %d\n", __func__, status);
 	/* Resubmit urb so we continue receiving IRQ data */
-	if (status != -ESHUTDOWN && status != -ENOENT) {
+	if (status != -ESHUTDOWN && status != -ENOENT && status != -EPROTO) {
 		usb_mark_last_busy(port->serial->dev);
 		err = usb_submit_urb(urb, GFP_ATOMIC);
 		if (err)
diff --git a/kernel/drivers/usb/serial/usb_wwan.c b/kernel/drivers/usb/serial/usb_wwan.c
index 628a75d12..236102bf3 100644
--- a/kernel/drivers/usb/serial/usb_wwan.c
+++ b/kernel/drivers/usb/serial/usb_wwan.c
@@ -140,10 +140,10 @@ int usb_wwan_get_serial_info(struct tty_struct *tty,
 	ss->line            = port->minor;
 	ss->port            = port->port_number;
 	ss->baud_base       = tty_get_baud_rate(port->port.tty);
-	ss->close_delay	    = jiffies_to_msecs(port->port.close_delay) / 10;
+	ss->close_delay	    = port->port.close_delay / 10;
 	ss->closing_wait    = port->port.closing_wait == ASYNC_CLOSING_WAIT_NONE ?
 				 ASYNC_CLOSING_WAIT_NONE :
-				 jiffies_to_msecs(port->port.closing_wait) / 10;
+				 port->port.closing_wait / 10;
 	return 0;
 EXPORT_SYMBOL(usb_wwan_get_serial_info);
@@ -155,10 +155,9 @@ int usb_wwan_set_serial_info(struct tty_struct *tty,
 	unsigned int closing_wait, close_delay;
 	int retval = 0;
-	close_delay = msecs_to_jiffies(ss->close_delay * 10);
+	close_delay = ss->close_delay * 10;
 	closing_wait = ss->closing_wait == ASYNC_CLOSING_WAIT_NONE ?
-			ASYNC_CLOSING_WAIT_NONE :
-			msecs_to_jiffies(ss->closing_wait * 10);
+			ASYNC_CLOSING_WAIT_NONE : ss->closing_wait * 10;
 	mutex_lock(&port->port.mutex);
@@ -273,7 +272,7 @@ static void usb_wwan_indat_callback(struct urb *urb)
 			__func__, status, endpoint);
 		/* don't resubmit on fatal errors */
-		if (status == -ESHUTDOWN || status == -ENOENT)
+		if (status == -ESHUTDOWN || status == -ENOENT || status == -EPROTO)
 			return;
 	} else {
 		if (urb->actual_length) {
@@ -435,8 +434,7 @@ void usb_wwan_close(struct usb_serial_port *port)
 	 * Need to take susp_lock to make sure port is not already being
-	 * resumed, but no need to hold it due to the tty-port initialized
-	 * flag.
+	 * resumed, but no need to hold it due to initialized
 	spin_lock_irq(&intfdata->susp_lock);
 	if (--intfdata->open_ports == 0)
@@ -478,6 +476,19 @@ static struct urb *usb_wwan_setup_urb(struct usb_serial_port *port,
 			  usb_sndbulkpipe(serial->dev, endpoint) | dir,
 			  buf, len, callback, ctx);
+#if 1 //Added by Quectel for Zero Packet
+	if (dir == USB_DIR_OUT) {
+		if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) && serial->dev->descriptor.idProduct == cpu_to_le16(0x9090))
+			urb->transfer_flags |= URB_ZERO_PACKET;
+		if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) && serial->dev->descriptor.idProduct == cpu_to_le16(0x9003))
+		if (serial->dev->descriptor.idVendor == cpu_to_le16(0x05C6) && serial->dev->descriptor.idProduct == cpu_to_le16(0x9215))
+#endif
 	if (intfdata->use_zlp && dir == USB_DIR_OUT)
diff --git a/kernel/drivers/usb/serial/qcserial.c b/kernel/drivers/usb/serial/qcserial.c
index b1e844bf3..469b202af 100644
--- a/kernel/drivers/usb/serial/qcserial.c
+++ b/kernel/drivers/usb/serial/qcserial.c
@@ -63,7 +63,7 @@ static const struct usb_device_id id_table[] = {
 	{DEVICE_G1K(0x05c6, 0x9202)},	/* Generic Gobi Modem device */
 	{DEVICE_G1K(0x05c6, 0x9203)},	/* Generic Gobi Modem device */
 	{DEVICE_G1K(0x05c6, 0x9222)},	/* Generic Gobi Modem device */
-	{DEVICE_G1K(0x05c6, 0x9008)},	/* Generic Gobi QDL device */
+//	{DEVICE_G1K(0x05c6, 0x9008)},	/* Generic Gobi QDL device */
 	{DEVICE_G1K(0x05c6, 0x9009)},	/* Generic Gobi Modem device */
 	{DEVICE_G1K(0x05c6, 0x9201)},	/* Generic Gobi QDL device */
 	{DEVICE_G1K(0x05c6, 0x9221)},	/* Generic Gobi QDL device */
@@ -165,9 +165,6 @@ static const struct usb_device_id id_table[] = {
 	{DEVICE_SWI(0x1199, 0x907b)},	/* Sierra Wireless EM74xx */
 	{DEVICE_SWI(0x1199, 0x9090)},	/* Sierra Wireless EM7565 QDL */
 	{DEVICE_SWI(0x1199, 0x9091)},	/* Sierra Wireless EM7565 */
-	{DEVICE_SWI(0x1199, 0x90d2)},	/* Sierra Wireless EM9191 QDL */
-	{DEVICE_SWI(0x1199, 0xc080)},	/* Sierra Wireless EM7590 QDL */
-	{DEVICE_SWI(0x1199, 0xc081)},	/* Sierra Wireless EM7590 */
 	{DEVICE_SWI(0x413c, 0x81a2)},	/* Dell Wireless 5806 Gobi(TM) 4G LTE Mobile Broadband Card */
 	{DEVICE_SWI(0x413c, 0x81a3)},	/* Dell Wireless 5570 HSPA+ (42Mbps) Mobile Broadband Card */
 	{DEVICE_SWI(0x413c, 0x81a4)},	/* Dell Wireless 5570e HSPA+ (42Mbps) Mobile Broadband Card */
@@ -177,7 +174,6 @@ static const struct usb_device_id id_table[] = {
 	{DEVICE_SWI(0x413c, 0x81b3)},	/* Dell Wireless 5809e Gobi(TM) 4G LTE Mobile Broadband Card (rev3) */
 	{DEVICE_SWI(0x413c, 0x81b5)},	/* Dell Wireless 5811e QDL */
 	{DEVICE_SWI(0x413c, 0x81b6)},	/* Dell Wireless 5811e QDL */
-	{DEVICE_SWI(0x413c, 0x81c2)},	/* Dell Wireless 5811e */
 	{DEVICE_SWI(0x413c, 0x81cb)},	/* Dell Wireless 5816e QDL */
 	{DEVICE_SWI(0x413c, 0x81cc)},	/* Dell Wireless 5816e */
 	{DEVICE_SWI(0x413c, 0x81cf)},   /* Dell Wireless 5819 */
Refer to this patch to go up
