Question About USB 3.0 AC Coupling Capacitors on ArmSoM CM5
Hello,
I have a question regarding the USB 3.0 SuperSpeed signals on the ArmSoM CM5.
According to the ArmSoM CM5 schematic, I do not see any AC coupling capacitors on the USB 3.0 SSTX/SSRX differential pairs.
In my carrier board design, I plan to embed a Microchip USB5744 USB 3.0 hub and connect it directly to the ArmSoM CM5 without using a USB connector in between.
In this case, should I place external AC coupling capacitors on both the SSTX and SSRX differential pairs on the carrier board?
Or are the required AC coupling capacitors already integrated inside the RK3576 or the CM5 module?
I would appreciate it if you could confirm the recommended implementation for a direct CM5-to-USB5744 SuperSpeed connection.
Thank you.
Hi, the CM5 module doesn’t have an AC coupling capacitor built in, so you’ll need to add one on your board design.
To expand on that: USB 3.x AC coupling is normally on the transmitter side, with a 100 nF capacitor in series with each line of the SuperSpeed TX pair. For a direct CM5-to-USB5744 link, that means caps near the CM5 on its SSTX pair and caps near the hub on the hub’s SSTX pair. Avoid placing caps at both ends of the same lane. Check the USB5744 hardware design checklist to confirm whether its upstream port already integrates them; if not, add them on the carrier.
