RK3576 SBC Introduction
RK3576 Brief datasheet
A low power, high performance AloT processor
Features RK3576
CPU
  • Quad Cortex-A72 and quad Cortex-A53
  • 1M8 unifed L2 cache for Cortex-A72
  • 512KB unified L2 cache for Cortex-A53
  • ARM cortex MO for user application
  • GPU
  • ARM Mali G52 MC3
  • OpenGL Es 1.1, 2.0 and 3.2, 0pencL 2.1, Wulkan 1.2
  • NPU
  • 6 TOPS*@INT8
  • Support int4/int8/int16/FP16/BF16/TF32
  • Support deep learning frameworks: TensorFlow, Caffe,Tfite, Pytorch, Onnx NN, Android NN, etc
  • Memory
  • 32-bit LPDDR4/LPDDR4X/LPDDR5
  • eMMC 5.1, SDIO 3.0 and SFC
  • UFS v2.0
  • Multimedia
  • H.265 HEVC Main10 L5.1 yuv444: 4K 120fps
  • H.264 AVC High10 L5.1 yuv422: 4K 60fps
  • H.264 MVC up to 1080P 60fps
  • VP9 Profile0/2 L5.1: 4K 120fps
  • AVS2 Profile0/2 L10.2.6: 4K 120fps
  • AV1 Main10 L5.3: 4K 120fps
  • 4K@60fps video encoders for H.264/H.265
  • Video Input
  • 16M Pixel ISP with HDR & 3DNR
  • Triple MIPI CSI-2 with 4-lane interfaces
  • 16-bit DVP interface, up to 150MHz
  • Display
  • Multiple display up to (4K@120 + 2.5K@60 + 2K@60)
  • HDMI v2.1/ eDP v1.3 Combo interface
  • MIPI DSI, 4 lanes
  • DP v1.4 and USB 3.0 combo (Type-C) interface
  • Parallel output interface
  • EBC output interface
  • Picture Quality post-process module
  • Audio Interface
  • 5x SAI interfaces, support I2S/thM/PCM mode
  • SPDIF TX and SPDIF RX
  • PDMO/PDM1 with 8 channels
  • Dual 2-ch and dual 4-ch ASRC
  • Digital Audio Codec with 2 channels
  • High Speed Interface
  • PCIe2.1/SATA3 combo interface with one data lane
  • PCIe2.1/SATA3/USB3.0 combo interface with one data lane
  • 2x RGMII interfaces
  • Industry
  • 2x CAN FD
  • 16-bit DSMC (Double Data Rate Serial Memory Controller)
  • Security
  • ARM TrustZone security extension
  • Secure boot and JTAG
  • Key ladder
  • Crypto (RSA 4096, AES 256, SHA-512...)
  • HDCP 2.x for HDMI and DP/eDP
  • SDK
  • Linux and Android
  • Others
  • Package Information: FCCSP698L(16.1x17.2mm, pitch: 0.6mm)
  • ### RK3576 Block Diagram[​](https://docs.armsom.org/blog/rk3576-sbc#rk3576-block-diagram)
    RK3576 Typical Application Diagram-AloT
    ArmSoM-Sige5 RK3576 SBC
    ArmSoM-Sige5 adopts the second-generation 8nm high-performance AIOT platform Rockchip RK3576, with a 6 TOPS computing power NPU and support for up to 16GB of large memory. It supports 4K video encoding and decoding, offers rich interfaces including dual gigabit Ethernet ports, WiFi 6 & BT5, and various video outputs. Compatible with multiple operating systems, it is suitable for ARM-based PCs, edge computing devices, personal mobile internet devices, and other digital multimedia applications.
    More details:Product Introduction: Sige5 | ArmSoM docs
    ArmSoM-CM5 RK3576 Compute Module
    The ArmSoM-CM5 is a Compute module powered by the Rockchip RK3576 second-generation 8nm high-performance AIOT platform. It integrates a quad-core Cortex-A72 @ 2.2GHz and a quad-core Cortex-A53 @ 1.8GHz, along with a dedicated NEON co-processor, a 6 TOPS NPU, and supports up to 16GB of large memory. It supports 4K video encoding and decoding, features a rich set of interfaces, and supports various operating systems.
    More details:Product Introduction: ArmSoM-CM5 | ArmSoM docs
    RK3576 Linux mainline support
