RK3588 Development Board
Rockchip RK3588 Development Board Introduction
ArmSoM-Sige7 RK3588 Development Board
The ArmSoM-Sige7 is powered by Rockchip’s latest flagship RK3588,octa-core 64-bit processor, with a max frequency of 2.4GHz, a 6 TOPS NPU, and up to 32GB of RAM. armsom-sige7 rk3588 development board
armsom-sige7 rk3588 sbc
More details:Product Introduction: Sige7 | ArmSoM docs
ArmSoM-LM7 RK3588 SOM/Cord board
The ArmSoM-LM7 adopts Rockchip’s latest flagship RK3588 which is eight-core 64-bit processor with a maximum frequency of up to 2.4GHz and a 6 TOPS NPU. It supports up to 32GB of large memory.
Supports 8K video encoding and decoding,with LGA packaging for stronger transmission capability and stability.
armsom-lm7 rk3588 core board
armsom-lm7 rk3588 development board
More details:Product Introduction: LM7 | ArmSoM docs
Product Certificate
armsom-sige7 rk3588 sbc certificate
RK3588 Linux mainline support
RK3588 Brief datasheet
A high performance, low power AloT processor
Features RK3588
CPU
  • Quad-core ARM Cortex - A75 and quad-core ARM Cortex - A55 processors
  • For each Cortex - A76: 64KB L1 instruction cache, 64KB L1 data cache, and 512KB L2 cache
  • For each Cortex - A55: 32KB L1 instruction cache, 32KB L1 data cache, and 128KB L2 cache
  • Big cluster and little cluster share 3MB L3 cache
  • MCU for low power control
  • GPU
  • ARM Mali - G610MC4
  • Supports OpenGL ES 1.1, 2.0, and 3.2, OpenCL 2.2, Vulkan 1.2, etc.
  • Embedded with 4 shader cores and shared hierarchical tiler
  • NPU
  • 6 TOPS @int8
  • Supports int4/int8/int16/FP16/BF16/TF32
  • Supports deep learning frameworks like TensorFlow, Caffe, Tflite, Pytorch, Onnx NN, Android NN, etc.
  • Memory
  • 54bit LPDDR4/LPDDR4x/LPDDR5
  • Supports eMMC5.1 with HS400, SDIO3.0 with HS200, NMe, SFC
  • Multimedia
  • H.265/H.264/VP9/AVI/AVS2 video decoder, up to 8K@60fps
  • H.264 AVC/MVC Main10 L5.0: 8K@30fps (7680x4320)
  • VP9 Profile0/2 L6.1: 8K@60fps (7680x4320)
  • AVS2 Profile0/2 L10.2.6: 8K@60fps (7680x4320)
  • AV1 Main Profile 8/10bit L5.3: 4K@60fps (3840x2160)
  • 1080P other video decoders (1, MPEG - 1/2/4, VP3, AVS1)
  • HDCP 2.x for HDMI and DP/eDP
  • MPEG - 1 up to MP: 1080p@60fps (1920x1080)
  • MPEG - 2 up to MP: 1080p@60fps (1920x1080)
  • VC - 1 up to AP level 3: 1080p@50fps (1920x1080)
  • VP8 version2: 1080p@60fps (1920x1080)
  • 8K@30fps video encoders for H.264/H.265
  • Video Input
  • 48M Pixel ISP with HDR&3DNR
  • Multiple (4×4lanes or 4×2lanes + 2×4Lanes) MIPI CSI - 2 and DVP interface
  • HDMI 2.0input to 4K@60fps
  • Display
  • Multiple display engine max to 8K
  • Dual HDMI2.1/eDP V1.4 Combo interface
  • Dual MIPI - DSI TX, 4 lanes
  • Dual DP v1.3 embed in USB 3.1, Audio, HDCP2.x
  • Audio Interface
  • 12S0/12S1 with 8 channels
  • 12S2/12S3 with 2 channels
  • SPDIF0/SPDIF1
  • PDMO/PDM1 with 8 channels
  • Digital Audio Codec with 2 channels
  • VAD (Voice Activity Detection)
  • High Speed Interface
  • Dual port USB3.1 with typeC& DP
  • Dual port USB2.0 OTG &dual port USB2.0 host
  • PCIe 3.0, 4 lanes or 2×2 lanes or 4×1lane
  • Three port PCIe 2.0/SATA 3.0
  • Dual RGMII interface
  • Industry
  • 2x CAN FD
  • 16-bit DSMC (Double Data Rate Serial Memory Controller)
  • Security
  • ARM Trustzone security extension
  • Secure boot
  • SDK
  • Linux 5.10
  • Android 12
  • Others
  • Package: FCBGA108BL Body. 23mm x 23mm
  • Ball pitch: 0.55mm
  • RK3588 Block Diagram
    rk3588 block diagram
    RK3588 Typical Application Diagram-AloT
    rk3588 typical
