Sige7 installation system to NVME startup
Overall steps:
  • Prepare an SD card or eMMC Module as a boot disk.
  • Burn Uboot firmware into EMMC.
  • Flush the system image to the NVME SSD.
  • Unplug the SD card and boot from NVME.
The firmware can be downloaded from the Armsom official website
Refer to the section on making a MicroSD boot disc to install the system on the SD card.
There is no SPI flash on the development board, and the Uboot firmware needs to be installed on the EMMC.
There are two storage paths for uboot firmware:
One is in the system image:
armsom@armsom-sige7:~$ ls /usr/lib/linux-u-boot-current-armsom-sige7/
idbloader.img  rkspi_loader.img  u-boot.itb
Another one is generated during the compilation of the source code:
armbian/build/output/debs/linux-u-boot
Use the dd command to flash firmware into EMMC:
dd if=./idbloader.img of=/dev/mmcblk0 seek=64 conv=notrunc status=none
dd if=./u-boot.itb of=/dev/mmcblk0 seek=16384 conv=notrunc status=none
Insert the NVME SSD into the board and verify that the NVME is recognized by the system
armsom@armsom-sige7:~$ lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
mmcblk0      179:0    0 115.3G  0 disk
mmcblk0boot0 179:32   0     4M  1 disk
mmcblk0boot1 179:64   0     4M  1 disk
mmcblk1      179:96   0  29.7G  0 disk
└─mmcblk1p1  179:97   0  29.4G  0 part /var/log.hdd
zram0        251:0    0  15.5G  0 disk [SWAP]
zram1        251:1    0    50M  0 disk /var/log
zram2        251:2    0     0B  0 disk
nvme0n1      259:0    0  13.4G  0 disk
└─nvme0n1p1  259:1    0  13.3G  0 part
As shown above the system already recognizes the NVME SSD as nvme0n1 (in Linux NVMe devices are usually recognized as nvmeXnY)
Copy the system image you want to run into the development board
 PC Host: scp  /path/to/img armsom@boardIP:/tmp
Then dd the system image into NVME on the board .
armsom@armsom-sige7:/tmp$sudo dd if=./Armbian_community_24.11.0-trunk.351_Armsom-sige7_noble_current_6.11.5_gnome-kisak_desktop.img of=/dev/nvme0n1 bs=1M status=progress
After removing the SD card, power up the system using the 12V/2A PD power adapter, then the system starts booting from NVME and HDMI displays the desktop
These instructions don’t work for me. After the reboot the system just boots from the EMMC.
The dd commands seem to execute ok.
In all othe Sige7 documentation it states EMMC can only be written by the usb serial interface after maskrom boot. Is this correct???
Is there any way to force Sige7 to boot directly from nvme drive?
This is a late reply, but in case you didn’t figure it out, you should look after the boot priority defined in your /etc/fstab. You can play around with it, and if you break things you can always access it from your sd card.
Thanks so much for this, Original post and followup. After running those dd commands I’ve now got it booting cleanly from nvme:
loop0 7:0 0 69M 1 loop /snap/core22/2412
loop1 7:1 0 33.7M 1 loop /snap/snapd/21761
loop2 7:2 0 69.2M 1 loop /snap/core22/1624
loop3 7:3 0 94.4M 1 loop /snap/lxd/30134
mmcblk0 179:0 0 58.2G 0 disk
├─mmcblk0p1 179:1 0 8M 0 part
├─mmcblk0p2 179:2 0 128M 0 part
└─mmcblk0p3 179:3 0 58.1G 0 part
nvme0n1 259:0 0 238.5G 0 disk
├─nvme0n1p1 259:1 0 4M 0 part
└─nvme0n1p2 259:2 0 238.5G 0 part /
