Hi,
I’m building Yocto for ArmSoM SiGe7 (RK3588) using meta-rockchip https://github.com/JeffyCN/meta-rockchip with:
MACHINE = "rockchip-rk3588-evb" -
Image:
core-image-minimal
After flashing the .wic to SD:
sudo dd if=core-image-minimal-rockchip-rk3588-evb.rootfs.wic of=/dev/mmcblk0 bs=4M status=progress conv=fsync
Only the rootfs partition appears. Bootloader (idblock, trust/fip, u-boot) is missing, so board doesn’t boot.
Questions:
What is the correct MACHINE or BSP for ArmSoM SiGe7?
How to generate a bootable
.wicwith U-Boot + Trust/FIP + Kernel + Rootfs? -
Is there an ArmSoM-specific Yocto BSP/layer instead of generic
rockchip-rk3588-evb? -
If manual flashing is needed, what’s the correct sequence (
idblock.img,trust.img/fip,uboot.img,boot.img,rootfs) for SD?
Thanks!
